View fan information to monitor the alarm status of the cooling ports in the chassis.
For platforms that support both back-to-front and front-to-back airflow, the airflow direction must be the same for both the power supply fans and the chassis fan.
- On the Device Physical View, select the Device.
- Select Chassis.
- Select the Fan Info tab.
Fan Info Field Descriptions
Use the data in the following tables to use the Fan Info tab.
Name |
Description |
Description |
Specifies a description of the fan location. |
OperStatus |
Specifies the operation status of the fan. |
OperSpeed |
Specifies the actual fan speed. |
OperSpeedRPM |
Specifies the current operational speed of the fan in RPM. |
